Old 08-02-2012, 02:39 PM   #1
Default Replace Starter in 2000 Winnebago Rialta
Can anyone give me an idea of the best way to replace the starter in a 2000 Winnebago Rialta?
I can get the wires and the outer bolt loose but the bolt next the firewall is buried.
grandnational10 is offline   Reply With Quote
Old 08-02-2012, 06:29 PM   #2
rem
Replaced mine last year. After dropping the skid plate the bottom bolt is easy. The top is alittle harder to get, You can get it from the top or bottom . I started on top but wound up taking it out from the bottom. I put a lift under the drivers side , made it alot easier
rem is offline   Reply With Quote
Old 08-02-2012, 07:02 PM   #3
Thanks for the reply.
Is the bolt on the top a bolt with a nut on it and the starter slides off the bolt, or does the bolt screw out?
I am having a hard time even seeing it.
Will the starter slide out or do you have to pry it out after you get both bolts off?
Your help is appreciated.
