Old 10-05-2015, 01:46 AM   #1
Default Red light and buzzer on oil
I own a 2002 HD and today, my oil indicator shows a red light and a buzzer. I was stuck in trafic and I had
to drive may be ten minutes before stopping, . I check oil level, it was fine. But VW oil sender monitor oil pressure. I scan the whole thing with a Scangauge and it shows no sign or didnt detect any problem. This thing happen a couple of time in september but everything was back to normal after a few seconds. But this time it keeps red. I suspected a rusty connector or a faulty sender since I have no code error on scan and I drove another 20 minutes to reach home in Longueuil without any problem of anykind.
Is this trouble is common on Rialta ? How can we check on actual oil pressure on system ? anyone knows where is located the sender ? I am in Montreal area. Anyone knows a good mechanic that knows without sending me to bankrupt ?
Thanks guys
richardtaillefer is offline   Reply With Quote
Old 10-10-2015, 04:16 AM   #2
The above problem was fixed succesfully by BT autorepair on Taschereau Longueuil QC. It was the high pressure oil monitor (Rialta have two senders) and it was changed and no more problem. I took the occasion to change oil and filter.
Old 10-13-2015, 11:26 PM   #3
bigdan's Avatar
ouffff réglé !
just came back from Côte Nord , just read this !
those VW sensors are often the problem ....good thing it was only this !
Salut
Daniel , 2000 FD
1996 C-21 Triple E ..... 86 Jeep CJ quite modded , 84 olds cutlass resto mod ,
On or off road , I`m on the road ! roadtrips !
bigdan is offline   Reply With Quote
