Red flashing light
The flashing light probably means that your coolant level is a little low. That's its secondary function. The level sensor can go bad, but it's not a common thing. The entire reservoir has to be replaced if it's bad.
I installed a Pioneer DEH-X3600UI from Walmart (about $80 at the time). You'll need to redo the adapter cable or buy a new one, but otherwise t works great. You should be able to use any single DIN radio, but all will need an adapter cable.
Duane
