Old 07-31-2012, 04:45 PM   #1
Default Rear Tires for 2000 Winnebago Rialta
I just purchased a 2000 Rialta and the rear tires were made in 2001 and I want to replace them. The only problem is I can not find 205/75R-15, load range D tires.
Is it possible to change to a 16 inch wheel so that it is easier to find load range D tires? If so, where can I fine the wheels and what size tires should I use?
I made a mistake on the tire size. It should have bee 215/70R-15, load range D.
grandnational10 is offline   Reply With Quote
Old 08-02-2012, 07:12 PM   #2
I have located some 225/70R-15, load range D tires and would like to know if there would be a problem using these on the back.
If anyone has used this size, please let me know if they work without any problems.
Old 08-12-2012, 11:28 PM   #3
My 2005 Rialta specs the rear tires at 215 65r 16 load range is C. The rear axle GAWR is 1800 Kg.
dhpenfield is offline   Reply With Quote
Old 08-12-2012, 11:28 PM   #4
Old 09-19-2012, 01:03 AM   #5
We just replaced our rear tires on our 2000 Rialta with 205/75 - R15 trailer tires, Load Range D. The size and load range works, and since it's on a straight axle, non-turning, should work fine. Much cheaper also!
nhb1022 is offline   Reply With Quote
Old 10-18-2012, 06:44 PM   #6
I just purchased original equipment tires for my 2001. I found them at http://www.tirerack.com. They are very knowledgeable and helpful. Good luck.
Jim
Jim Sturges is offline   Reply With Quote
