Old 06-22-2010, 02:28 AM   #1
Default raise chassis
I have a 1997 its so low to the ground has anyone tried to raise it i have 15inch wheels and thought of going to 17s not sure about the wheelwell clearance any ideas?
martin clark is offline   Reply With Quote
Old 07-15-2010, 09:41 PM   #2
D0N
I'm told you can crank up the torsion bars in the front to raise just the front. Check into that.
New shocks might help too. You can buy 4 new monroes for under $200.
Also if you have the stock sized 195 tires on the front and 215 tires on the rear, it's not going to sit level.
The 195's are 1.5 inches shorter than the 215's.
I don't know why winnebago chose to use 2 sizes of tires???
D0N is offline   Reply With Quote
