Old 01-22-2016, 07:43 PM   #1
Default /Playing a DVD in the existing VCR Player
Has anyone found an adapter that will let you Play DVD movies on the exsisting VCR player that is in the Rialta...........With all our electronic gadgets....someone has bound to have make such an adapter...
blackhorse is offline   Reply With Quote
Old 01-24-2016, 09:01 PM   #2
bigdan's Avatar
I dint even know there was a VCR player in a Rialta .....
And then at the age it must be ,..is it worth buying an adapter if ever it exists ......
I bought a brand new flat sreen TV & DVD player 22" for dirt cheap ....
1996 C-21 Triple E ..... 86 Jeep CJ quite modded , 84 olds cutlass resto mod ,
On or off road , I`m on the road ! roadtrips !
bigdan is offline   Reply With Quote
Old 03-20-2016, 08:09 PM   #3
I removed my VCR player from the back and am contemplating replacing it with a small DVD/Blueray player. The power is 12V and the connections to the front TV look like RCA jacks ( composite ). If I find a solution, I'll post it here.
rtsukijima is offline   Reply With Quote
Old 03-20-2016, 10:16 PM   #4
Bruceper's Avatar
If such a beast existed, and they don't, it would be so complicated it would cost way more than it's worth. The issue being that a VCR doesn't have a single head like a cassette player, those adapters were cheap and easy back in the day.
I would suggest you pull the unit out and see if there is any type of auxiliary inputs at the back. That way you could just play from a dvd player and input directly into the tv or into the VCR.
Old 03-23-2016, 12:35 AM   #5
moving forward..what we did with our 2006 B was to strip out all the old stuff, tv, converters etc filling a large box. bought a new 20" samsung from costco for under $130...digital- no converters have a usb in and on board media player controlled from remote...put movies, tv shows downloads etc onto usb thumb drive and play on tv. a thumb drive can hold hundreds of hours of movies...in no space at all. mike
