Old 10-24-2015, 04:26 PM   #1
Default pictures needed please help!! 22FD under the bed pics would greatly help!
Hello, I am a new 22FD rialta owner. I'm new to this forum so thanks ahead of time.
I need a picture or pictures of basically the "inverter" area under the bed. I am a train mechanic but even I am having a hard time working on a basket case Rialta I picked up. The previous owner removed something or added something then removed on top of where the genrerator sits (metal box that the inverter is mounted to). Any and all pics would be greatly appreciated. I googled and can't find even one picture.
Regards
jp.
illfrom is offline   Reply With Quote
Old 10-25-2015, 01:52 AM   #2
bigdan's Avatar
do yo mean 12V to 120 V inverter ?
1996 C-21 Triple E ..... 86 Jeep CJ quite modded , 84 olds cutlass resto mod ,
On or off road , I`m on the road ! roadtrips !
bigdan is offline   Reply With Quote
Old 10-25-2015, 06:04 PM   #3
Hello, I'm not sure to be honest. I need a pic of under the "bed towards where the generator would be. Next to the inverter. I may not have enough info to sound educated about this.
The inverter should plug into a "110v" receptacle and then take that power and convert to 12v etc. correct?
Is it safe to assume the generator puts out 110v? If so, then I simply need a pic of the area in the corner when the "inverter with fan" bolts to and the top? The reason is, this guy had something mounted on the top shelf of the metal when the generator sits, but it is not there now?
Thanks.
Old 10-25-2015, 11:18 PM   #4
bigdan's Avatar
you should have a look at
http://www.rialtainfo.com
lots of infos there
Dan
Old 10-26-2015, 07:36 PM   #5
Yes thank you. I could not find the pics there. I'm hoping someone has time to life up their bed and take a pic and upload. Thanks.
Old 10-26-2015, 09:38 PM   #6
bigdan's Avatar
I have a 00 FD ..............
If I lift the bed , there is nothing in the storage space under the bed ..........
Old 10-26-2015, 10:04 PM   #7
It's not right under the bed, it's towards the wall where all the electrical and pumps are at. Thanks for looking.
Old 10-27-2015, 07:58 PM   #8
bigdan's Avatar
ok ,
give me about an hour ....Ill do it !
Dan
Old 10-27-2015, 08:05 PM   #9
Oh, wow thanks a lot man!!! I'm just trying to make sure I'm not "missing" any critical items/etc.
Old 10-27-2015, 08:05 PM   #10
My email is ILLFROM@GMAIL.COM
Old 10-27-2015, 08:35 PM   #11
bigdan's Avatar
I took some pics but cant put them here ...
there is no browse function
give me your email
Dan
Old 10-28-2015, 08:14 PM   #12
mloganusda's Avatar
I will try this.
Old 10-28-2015, 08:16 PM   #13
mloganusda's Avatar
At the top of the photo is where the converter is located, see the fan & unit is mounted on the side of the generator wall.
Old 10-28-2015, 11:13 PM   #14
bigdan's Avatar
sent 7 pics to your mail ( in regular letters )
Dan
p.s how did you do Mike ??
Old 10-28-2015, 11:46 PM   #15
Hello, thanks so much man. It helps a lot. I sent you an email just a moment ago.
Old 10-29-2015, 08:09 PM   #16
mloganusda's Avatar
When you reply, there is a piture of a tree about the middle for options to insert or edit image. You need to have a URL source to upload into the box. I use photobucket and select direct to copy and paste into the box.
Old 10-29-2015, 09:32 PM   #17
Nice flood though.
Old 10-30-2015, 11:02 PM   #18
bigdan's Avatar
ok that`s why I dont do it this way,
load it in photobucket then load it here .....
most forum I go have the "browse" function , so easy !
Dan ,
