Old 08-29-2015, 05:11 PM   #1
Default Onan Generator model # 3kvc-83c- oil change
How do i change the oil in this generator, i can not find the drain plug. what grade oil ? this site has been a great help to me..many thanks..Jerry
jerry durand is offline   Reply With Quote
Old 08-30-2015, 06:17 PM   #2
mloganusda's Avatar
I have the same generator and the drain plug is located on the bottom pan, inside the hole. Use a socket and extension to remove it and expect oil to drain down your hand and arm. Use one quart of 30W oil and reinsert the dipstick, but do not screw the cap in, and check level of oil.
