Old 08-05-2015, 05:44 PM   #1
Default Onan 2800 fuel pump replacement
Do I have to remove a Onan 2800 KVC from the RV to replace a fuel pump?
zzellmer is offline   Reply With Quote
Old 08-06-2015, 06:16 PM   #2
mloganusda's Avatar
You do not have to remove the generator. There is a plate on the bottom with about 14 screws/bolts that you remove and the pump is right there.
