Old 07-04-2012, 07:44 PM   #1
Default Norcold Refrigerator run off-center: damage likely?
I recently had my Norcold model N300 on my 2002 Rialta serviced. Unfortunately, and unknown to me, Camping World left it running! I parked the Rialta at home with a forward-back angle of 0.2 degrees; the side-to-side angle was 4.7 degrees. Specs for the Norcold are 6/3 degrees maximum.
The repair was done on Friday. I picked up the Rialta on Monday. It was parked from Monday evening to Wednesday evening at the angles stated above for those two days, still running. It used a half tank of LP gas running from Friday through Wednesday.
What is the likelihood of damage to the cooling system, as Norcold states on page 4 of their Owners Manual (Model N3000 3-way unit) when run for that period off-center?
Best regards,
Bill Blask
Bblask75 is offline   Reply With Quote
Old 07-04-2012, 08:18 PM   #2
rem
It should be ok, let it sit for a few days off. Then level & restart hopefully it will be ok. This happened to me also parked in the yard testing the unit. A few days went by before I realized I left in on. But I releveled & everything was fine.
Rem
rem is offline   Reply With Quote
Old 07-07-2012, 12:06 AM   #3
Rem,
Thaks for the encouragement. The dealer agreed to look it over and test it. And replace the half tank of LP it used. So far, so good.
Bill & Paulette
Old 07-07-2012, 07:38 PM   #4
rem
Glad to hear that. To bad you could not get the panel. I'll look around my area & if I'm lucky will post.
Rem
