Old 06-14-2015, 04:19 PM   #1
Default new member seeking comments on maintenance
Hello! Recently bought a 2002 QD with only 23,000 miles on it. I'm planning on doing a fluid change on the coolant, transmission and brake lines. Being that it's 13 years od this seems like a prudent measure. Both front and top air units have been replaced, generator over hauled.
Does anyone have comments on other preventitive points to consider?
Thanks, Dave
dave luger is offline   Reply With Quote
Old 06-14-2015, 11:29 PM   #2
bigdan's Avatar
definitely a good move to change all fluids regurarly .....
brake fuid gets contaminated by humidity .....and the transmission fluid collects all kinds of little debris and if overheated has to be changed also
coolant should be changed every 5 years ....or when tested acid ...
1996 C-21 Triple E ..... 86 Jeep CJ quite modded , 84 olds cutlass resto mod ,
On or off road , I`m on the road ! roadtrips !
bigdan is offline   Reply With Quote
Old 06-15-2015, 02:42 PM   #3
thank you!
