Old 07-01-2012, 11:02 AM   #1
Default Monitor Panel
Hello, we have a '01 FDD and the monitor panel lights for the tank levels don't work.
Can it be fixed or do I need a new one? Do you change just the circiut board or the whole thing,and where would one be found?
Thanks,Gene
Gene is offline   Reply With Quote
Old 06-05-2013, 02:31 AM   #2
Thanks,Gene
Did you get this figured out? I have a 2001 HD and the panel doesn't work. I called Ventline and they can send me a replacement panel for $105. Not sure if there is a way to test the panel to see if it is indeed the problem
michaelmiracle is offline   Reply With Quote
