Old 01-19-2016, 10:46 PM   #1
Default Low hrs generator Access
I have a very low hour generator that won't start. I check fuel there is some in the bowl checked spark its hot. So here is what I am thinking that it hasn't been run long enought o get varnish out of the carb. Everything say runit for 1/2hr at least every month, So my guess is the carb is gunked up and needs cleaning or replacement. Any suggestions?
Thenext problem is access to the genset. There must be a way to get the puppy out of compartment it is in so you can work on it with relative ease. I am think there must be a few bolts to remove that would allow the unit to slide out at least a little but maybe not. Does anyone have a suggestion other than baby size hands
Thanks
Fstued
fstued is offline   Reply With Quote
Old 01-19-2016, 11:50 PM   #2
bigdan's Avatar
the unit is bolted form under to the frame .....it has to be lowered to gain access !
a good floor jack and patience should get it
Dan
1996 C-21 Triple E ..... 86 Jeep CJ quite modded , 84 olds cutlass resto mod ,
On or off road , I`m on the road ! roadtrips !
bigdan is offline   Reply With Quote
Old 01-21-2016, 04:22 PM   #3
mloganusda's Avatar
Here is the carburetor Repair Kit from Cummins dealer.
Part # 146-0651 $27.98 + taxes
My local Cummins dealer is:
Nashville Branch
706 Spence Lane
Nashville, TN 37217
(615) 366-4341
Check for your local Cummins dealer and have him order the kit for you. Also check with any local lawn mower repair shops for the repair kit. The carburetor has been removed without dropping the entire unit but hard to reattach the interinal nut.
