Old 01-02-2015, 08:18 PM   #1
Default Installed Garmin Wireless Backup Camera on my Rialta... Easy and works Great !
I have had my Rialta for a couple of years. We have a Garmin RV 760MLT GPS
I just installed the Garmin BC20 Wireless Backup Camera on the Rialta
It was so easy. Removed the 2 cubby trays in rear near windows ( just remove 2 screws in each tray )
Drill 1/2 hole thru fiberglass that will be centered between the tire well and AC cord storage compartment
Drill 3/8 hole thru plastic bumper above License Plate
Fasten Camera Bracket to top of License Plate Area
Thread Camera cable thru hole and up thru 1/2 hole ( I put 1/2 Diameter Tubing thru hole for chaf protection )
Plug camera cable into wireless transmitter and power into reverse lights wiring which are easily seen there
The Garmin RV 760MLT GPS picks up the signal when you are in reverse and displays.
Now I can backup within a few feet of anything without worrying about hitting it
Chuck Email CLCJR54@hotmail.com
Chuck711 is offline   Reply With Quote
Old 06-15-2015, 10:05 AM   #2
Would you happen to have pics of install? Or if anything can you take a few to post here so we can see finished install? Looking to install one on my 2004 HD and just looking for ideas. I was looking at a simple license plate bracket install, but i think that will be way to low.
Thanks, and happy motoring!
jtckane114 is offline   Reply With Quote
Old 06-17-2015, 09:55 AM   #3
bigdan's Avatar
I want to install one on mine too.....
Ill try to put the camera as hihg as possible for a better angle .....
1996 C-21 Triple E ..... 86 Jeep CJ quite modded , 84 olds cutlass resto mod ,
On or off road , I`m on the road ! roadtrips !
bigdan is offline   Reply With Quote
Old 04-10-2016, 11:32 PM   #4
Anyone know if the two trays Chuck says are in back near the window can be found on a Rialta 2002 QD? I have one tray with two cupholders but no screws are visible. And my rear light is above the window. Or course, I can run the cord along the top shelf and down into the table holder but only after I confirm what I need to do.
stephanietwest is offline   Reply With Quote
