Old 10-22-2014, 03:06 PM   #1
Default hot water tank
How do I fill the hot water tank without filling the fresh water tank???
How does the hot water tank get filled???
robinmorton0@gmail.com
robin005 is offline   Reply With Quote
Old 10-23-2014, 09:18 AM   #2
Normally, water is pumped from the fresh tank to all the other plumbing, including the water heater. You should be able to connect a hose to the city water connection on the driver side to fill everything except the fresh tank. If the check valve isn't working, this would also fill the fresh tank though.
Duane
TXPigeon is offline   Reply With Quote
