Old 10-14-2012, 01:46 PM   #1
Default fuse location freshwater pump 1997 rialta
fuse location for freshwater pump switch on 1997 rd! tested freshwater pump works fine! But no power to the freshwater pump switch Up date, found fuse was fine what I did was remove the switch from wall and use hot wire to jump pump on switch and it reset something in small circuit board and now pump switch is working, not sure I would recommend this for others that may have a switch problem, But I was a my wit end and tried it to see what would happen!
irish1940 is offline   Reply With Quote
