Old 06-09-2015, 02:57 PM   #1
Default fuel pump going out
Has anyone changed out their on fuel pump??? If so I have a 96 model and was wondering if there is anything I should look out for before I tackel this job.. Thank you Herb
1996 rialta
owner since november 2014
10,000 and counting @ 54000
herbert is offline   Reply With Quote
Old 06-09-2015, 10:48 PM   #2
mloganusda's Avatar
Herbert, you need to go to this site for lots of information on the Rialta.
http://www.riatlainfo.com
Another owner had his fuel pump changed out and did a write up about how to do it. Under the drivers seat and under the carpet is a cutout hole to remove the fuel pump with out dropping the tank. I believe he removed the driver seat to get to the cutout area.
Some auto have this same way to remove the fuel pump with out dropping the tank.
Old 06-11-2015, 02:21 PM   #3
bigdan's Avatar
quite easy to do
remove driver seat
lift carpet
look for a screwed on plate on floor
remove it , voila , access to the fuel pump !
Dan
1996 C-21 Triple E ..... 86 Jeep CJ quite modded , 84 olds cutlass resto mod ,
On or off road , I`m on the road ! roadtrips !
bigdan is offline   Reply With Quote
