Old 10-13-2012, 02:57 PM   #1
Default fresh water pump location
question! where is the freshwater pump on 1997 rialta RD? is water required in the tank in order for the pump to turn on?
irish1940 is offline   Reply With Quote
Old 10-14-2012, 11:11 AM   #2
rem
I have the HD & my pump is under the rear seat-bed. The pump should be located next to your water tank.And no the pump willl run with out water, I donot advise this the pump could burn out
rem is offline   Reply With Quote
Old 10-14-2012, 01:17 PM   #3
thank you I found it! problem I have now is the pump switch wil not turn on looking for fuse. hot wired pump and the pump is working fine
rem said:I have the HD & my pump is under the rear seat-bed. The pump should be located next to your water tank.And no the pump willl run with out water, I donot advise this the pump could burn out
