Old 07-01-2010, 12:24 AM   #1
Default Door seal on coach needs replacing - where can I find replacement seal?
The rubber seal around the coach door on our 1998 Rialta is hardening around the edges and chipping away and needs to be replaced. Where can I get a replacement seal? Is there some generic seal that will work that I can get readily? Anything special I need to know before I begin this task?
Neena is offline   Reply With Quote
Old 07-15-2010, 09:28 PM   #2
D0N
You can get this seal from winnebago. They sell it by the foot for about $4 a foot. They'll tell you that you need 15 feet as I remember but you only need around 12 feet.
Measure both sides and the top of the door and buy just that many feet.
I found it difficult and time consuming getting the olf gasket off but the new one went on very easy. It's a stick on seal.
Good luck!
D0N is offline   Reply With Quote
Old 10-07-2013, 02:35 PM   #3
Don
What is the door seal part number? I think I need the 075673-04 000 in black for my 99HD, but I can only find a 075671-04 listed at Winnebago.
thanks
Frummox is offline   Reply With Quote
