Old 05-19-2010, 04:41 PM   #1
D0N
Default Does the coach door have a dome light switch on it?
Hi folks... my dome light is acting up. When its switch is placed in "door" mode, it comes on when either front door is open and goes off when they close. However, after all doors are closed, the dome light stays on dimly and flickers.
When wiggling the spring thing (I assume it houses the coach door wires) on the coach door, the flickering changes. I have to believe that there's a switch somewhere on the coach door that makes the dome light go on and off?
Am I correct? If yes, where is that switch located on the coach door?
thanks!
D0N is offline   Reply With Quote
