Old 02-14-2012, 07:46 PM   #1
Default Change or not change the transmission fluid?
I have a 1999 Rialta HD. I've heard that the transmission fluid should not be changed but the manual says every 40K miles. My concern is that my Rialta only has 11K miles on it but it is 13 years old so my question is, due to it's age should I change the transmission fluid or not?
funrunjack is offline   Reply With Quote
Old 02-15-2012, 11:33 AM   #2
rem
I would call a VW dealer & ask. I have 39 000 on mine & have not changed it as of yet.
rem is offline   Reply With Quote
Old 03-30-2012, 11:29 PM   #3
There are a duo of fast Bathtub Faucets variations that can be completed in the meals area to carry it up-to-date its overall look composed ablation the wardrobe doorways, kitchen countertops and the room faucets.Several periods the devices in theKitchen Faucets are well thought-out but the reality is, they may sketch attention to the faucets and if the cooking area is clean, old formed or otherwise inactive sink faucets will take away from the common overall look Shower Heads.At the same time as changing out the faucets, it may seem like rather a process, it is actually simple enough if the only factor to be changed is the recognizable hold and not the regulator Faucet Accessories construction. Usually, you will discover a small cap embrace, a twist will quickly be taken out.The twist is separated and the tap hold raises off. A clean hold may be located over the getting older come, generating Antique Faucets an immediate clean look.
Faucets
dreamfaucets is offline   Reply With Quote
