Old 10-22-2014, 08:25 PM   #1
Default Bad Vibrations
I am a new member and unfamiliar with this website. Please ignore previous posting details.
When starting engine in a 1995 Rialta (5 cylinder) I get no unusual noises or behaviour . I can put transmission in PARK or NEUTRAL -and engine idles properly. But if I now switch engine into DRIVE I get immediate strong vibrations (at idle) which will continue until I start moving. None of these noises occur at other speeds until vehicle stops, then the vibrations again until going back into NEUTRAL or PARK.
HELP
Bill
(8O5) 7O9 4274
bilhadji is offline   Reply With Quote
Old 10-23-2014, 09:20 AM   #2
That's a sign of a bad transmission mount.
Duane
TXPigeon is offline   Reply With Quote
Old 10-23-2014, 02:37 PM   #3
bigdan's Avatar
open the hood ,
PUT THE SAFETY BRAKE ON ....
while you are watching under the hood,
have someone start the engine put the tranny in Drive ,then Reverse
if the tranny moves more then it should ,the mount is shoot !
Normaly it should barely move ......
Dan
1996 C-21 Triple E ..... 86 Jeep CJ quite modded , 84 olds cutlass resto mod ,
On or off road , I`m on the road ! roadtrips !
bigdan is offline   Reply With Quote
Old 10-25-2014, 06:22 PM   #4
bigdan said:
open the hood ,
Dan
Hi Dan,
Thanks very much for your suggestion. I hope replacement(s) is straight forward.
Bill
