Old 04-13-2011, 02:57 AM   #1
Default awning
can you put a 12' awning on rialta? is Fiamma a good one?
kkferlito is offline   Reply With Quote
Old 09-23-2011, 12:21 PM   #2
Default awning
We just purchased a Fiamma 11'7″ awning with the mounting brackets for our 95 Rialta. The awning will fit but does anyone know how, if the brackets need support on the inside, what sealant to use & where to mount the brackets?
mini winnie is offline   Reply With Quote
Old 09-23-2011, 01:13 PM   #3
rem
Default awning
Any good water proof sealant should work fine. Mounting it could be another story. You will have to mount it then see if you have to make & add supports
rem is offline   Reply With Quote
