Old 08-13-2022, 06:20 PM   #1
Default Alde 3010
My Alde will not heat water using electric power. Using gas it works fine. Alde says it can not be fixed and suggest I get a 3020. Has anyone else had this problem?
Winnie 2015 is offline   Reply With Quote
Old 08-17-2022, 03:02 PM   #2
mloganusda's Avatar
Highlighting your model, I found some solutions to your problem. Try searching for solutions to fix your board, if it is broken. They mention a soldered fuse on the board that is blown.
Old 08-19-2022, 04:32 PM   #3
mloganusda's Avatar
Also check the electric heating element to make sure it is not broken. If broken, no electracy will pass thru and not heat up.
