Old 07-16-2015, 12:31 AM   #1
Default Adding ATF cooler bypass
I'm adding a ATF cooler with bypass because I live in a colder climate. I was wondering if it matters how the bypass is installed because I do not know the direction of the transmission fluid. They have arrows of the flow on the bypass so I think it would matter? Aside from starting the vehicle and watch the direction of the flow. Any info would be appreciated. Thanks Gregg
gjkristi is offline   Reply With Quote
Old 07-20-2015, 04:13 AM   #2
bigdan's Avatar
as per Duane ,
the transmission fluid comes out at the back ouput .....( hotter )
1996 C-21 Triple E ..... 86 Jeep CJ quite modded , 84 olds cutlass resto mod ,
On or off road , I`m on the road ! roadtrips !
bigdan is offline   Reply With Quote
