Old 02-21-2014, 08:57 PM   #1
Default AC BTU
My 03 HD has the original Mach AC installed. I tried to locate the BTU's for the AC by using the model number but, am not able too find what I need.
Does anypne out there know the BTU's for the Mach AC?
I'm asking because I want to upgrade to a Heat Pump 13.5 KBTU MAch III PS but, I believe I may be able to use the Mach 1 PS rated at 11KBTU since I believe also that the original not to great unit is a 9KBTU unit.
Any information is appreciated.
fs23454 is offline   Reply With Quote
Old 02-22-2014, 03:21 PM   #2
mloganusda's Avatar
Default AC BTU
My 2004 has the high efficencey roof A/c rated at 8K btu and your unit may be the same. Several Rialta owners have upgraded their a/c units to the 13.5K unit for better cooling. The only problem that they have run into is that the generator has a hard time running the bigger unit. You can only run the larger roof a/c with the generator, as it takes almost all the wattage and leaves little to run microwave or other ac appliances. The smaller 11K will be better, inmho, as it will draw less wattage and is a lower profile to wind resisantance. One way to increase cooling is to cover you windows with insulating wrap to decrease heat intrusion in summer and cold intrusion during winter.
Old 02-22-2014, 09:23 PM   #3
Default AC BTU
Do you have the model number of your unit?
The model on my Rialta now is 8632B781.
For the power draw on the larger 13.5KBTU (total fan High and compressor is 10.1 AMPS heating or cooling heat pump, 15.7 if on electric heat strip) is actually less than the model I have now according to the rating plate on the unit (10.1 forcompressor and 2.3 for the fan on high)
The generator handles my exisiting unit well if I don't run the microwave at the same time so, it should do Ok with the new unit I'm considering.
Thanks for responding.
