Old 11-07-2016, 01:47 AM   #1
Default 99 rialta power window in op
99 rialto drivers side power window switches do not work. I was troubleshooting my power mirrors not working and some how broke the power windows. they worked before. I heard what sounded like a c/b popping but cannot find the breaker. any help is greatly appreciated. we just bought the coach and want to get on the road
chief is offline   Reply With Quote
Old 11-08-2016, 06:25 AM   #2
check the forums on this site: https://groups.io/g/Rialta-Tech/topics
In my experience, the power windows are on a breaker ( not a fuse ) and it should auto reset itself. The most likely culprit is a broken wire in the "elbow" of the wiring harness ( the one that is under the rubber boot between the door and the cab) I had both my power windows and power mirrors stop working at the same time and the problem was a broken ground wire in the boot.
Robert
rtsukijima is offline   Reply With Quote
