96 rialta 2.5 5 cyl gas engine runs bad cold
could be :
your IAT ( intake air temp sensor )
coolant sensor
cold start injector at the intake end ( driver side )
1) verify if you have any voltage at cold injector when cold ( before starting engine but ign "ON")
if so , start engine disconnect it : same or worse
if worse,reconnect, if same could be it …..
next :
disconnect coolant sensor
same or worse ,if worse
reconnect if same could be it ,
disconnect IAT ( intake air temp )
if worse , reconnect …..
Dan
1996 C-21 Triple E ..... 86 Jeep CJ quite modded , 84 olds cutlass resto mod ,
On or off road , I`m on the road ! roadtrips !
