Old 10-28-2015, 03:15 AM   #1
Default 5 Cylinder or 6 Cylinder?
Hi, I am a newbie looking for a rialta and have yet to determine if I should look for the 5 cylinder or V6. I have read a few pros and cons for both but have not yet found good arguments for or against either. I understand that the 5 cylinder was evidently 95 and & 96 and everything up was the V6. In addition, it looks like the changed the V6 later for a higher output engine, I assume by installing DOHC. I am trying to determine if there is a huge difference between the older to newer generations. Any help, recommendations, curses or other would be appreciated. Thanks.
inspectork is offline   Reply With Quote
Old 10-28-2015, 12:59 PM   #2
bigdan's Avatar
my opinion after owning a 5 cyl & now a VR6.....
Get a VR6 for its power/ fuel consumption ratio ......
the 2.5L 5 cyl is a tough engine but underpowered for hilly situations ....( 100 hp for over 6000lbs )
between the 12V & 24V is a question of choice
I have tried both .....
felt a small difference at high rpm ...otherwise quite similar
the 12V runs at lower rpm for same speed ....
whatever you buy : add a transmission oil cooler if it is not already equiped .....
Dan ,
1996 C-21 Triple E ..... 86 Jeep CJ quite modded , 84 olds cutlass resto mod ,
On or off road , I`m on the road ! roadtrips !
bigdan is offline   Reply With Quote
Old 10-28-2015, 10:37 PM   #3
Thanks for the info Dan. Also, do I understand correctly that the equipment (generator, roof and cab AC, refrig, etc) are better on the 97 and up models?
Old 10-28-2015, 11:04 PM   #4
bigdan's Avatar
not that I know of ......they are all similar !
generators and fridge are to be maintained......
I took out my generator and had to maintain my fridge a couple of times
next move would be a 12V danfoss compressor fridge
Dan
