Old 09-17-2015, 10:44 PM   #1
Default 2002 Rialta tires source
I am having frouble locating the tires for this vehicle, used to be available from continental tires. Does
anyone know where to source 195-65r-16 front, 215-65r-16 rear. Much thanks for any help. i just purchased vehicle and want to hit the road. Steve
sbolse67 is offline   Reply With Quote
Old 09-18-2015, 06:05 AM   #2
Can you not find the Conti Vanco 2 anywhere?
http://www.continentaltire.ca/.....tml?page=1
they are avaialble in 215/65/16
Robert
rtsukijima is offline   Reply With Quote
Old 09-18-2015, 11:19 AM   #3
bigdan's Avatar
I would go for 215`s all around .....
mine isnt ....and will be , when due for tires !
Any tire manufacturer with the right specs will do
seems like nokians had trouble ...otherwise no object
Dan
1996 C-21 Triple E ..... 86 Jeep CJ quite modded , 84 olds cutlass resto mod ,
On or off road , I`m on the road ! roadtrips !
bigdan is offline   Reply With Quote
Old 09-19-2015, 04:59 AM   #4
If you do go with 215's all around, you might want to keep the best 195 for the spare.
Old 07-01-2016, 11:47 PM   #5
Robert, the tire size on my 2001 is 215 70, not 215 65 is the lower profile ok or will it cause problems in the long run.
Don B is offline   Reply With Quote
Old 07-02-2016, 01:36 AM   #6
You should double check the door jamb as it should list your correct tire size, type and inflation pressure.
according to most Rialta info I have seen, the 65 series was standard fitment for the 16" wheel from 2002-2005 and the 70 series was used on the 15" wheel from 1996-2001
see here:
Tires & Wheels
Also check the Rialta groups:
Tech:
https://groups.io/g/Rialta-Tech
General:
Old 07-04-2016, 06:05 PM   #7
My 2001 calls for the 215 70 . . .
After an exhausting internet search, I find there is a new load rating system , using a two or three digit number (can't find "C" anywhere). It appears something in the high 90's should work - I find very, very few tire descriptions that use "ply" rating. Someone with tire knowledge, is a 90's load rating equivalent to a 8 ply count? I couldn't locate anything on the web that told me.
I intend to go with 215-70 all the way around. If there is a good reason not to someone speak up - several of you say you have or will do it.
Old 07-04-2016, 10:18 PM   #8
Bruceper's Avatar
The "90's" number you're looking at is a load index, meaning how much weight those tires can safely carry.
The load range is a letter, and designates the ply count. The ply count does not mean that tire actually has that many plies, but it indicates how strong the plies are. It also designated how much weight those tires can carry safely.
As a note, most North American tires sites state the load range. ie 215/70/16 E. Where E is the load range.
Load index is a European rating, load range is north american.
Old 07-05-2016, 04:14 AM   #9
I would be concerned if the Load Rating was in the 90's. The tires should have a load index of 104 or higher.
Tires & Wheels
Old 07-06-2016, 04:08 PM   #10
mloganusda's Avatar
Thumbs up
Try this site for tires:
Thunderer R402 Commercial Tire | Thunderer Tires
Tirerack.com
discounttires.com
tires by web.com
Mike Logan
Formerly 04' Rialta
Smyrna, TN
