Old 04-26-2013, 10:42 PM   #1
Default 1995 gas tank pressure
There is a mild gas smell and when the gas cap is removed there is a large amount of built up air pressure in the tank. We have had it in for repair twice with broken seals. The gas tank is never below half a tank. Does anyone else have this problem and what is the fix? Our volkswagon mechanic is not able to provide any solutions. Thanks Brian
mini winnie is offline   Reply With Quote
Old 06-12-2013, 03:10 AM   #2
I have a similar problem on my 1997 Rialta. Fuel gauge was showing full when it should have been 3/4 to half full. Smelled gas. Pulled over and heard gurgling from the fuel tank. Releaved pressure from tank by slowly opening gas cap. A lot of pressure vented. Allowed vehicle to cool down for about 20 minutes. I was driving in direct sun at about 85°F. Problem went away at night when it cooled off. Fuel tank is about 6″ off the ground and can get hot if it's hot out. I got a code P0440 – Fuel Ventilation System. Not sure what's wrong with it. Will post if I find the problem. Also, gas gauge was reading accurately and there wasn't so much pressure once the temperature went down.
newuserguy is offline   Reply With Quote
