09-21-2015, 02:59 AM
#141
Originally Posted by wincrasher
Just get a chest type compressor freezer. They work pretty well. You just need to find a place to put it in a 170.
Great idea! I thought of that right after I posted. Don't take up too much room and very efficient and well insulated. Waeco (Dometic) gets high marks. You can set it up as fridge or freezer. Come in many sizes. The most you might need to do is run a new 12V & 110v line and outlet to its location, if not there already.
BobB
'99 VW EVC
09-21-2015, 04:58 AM
#142
Have you ever been inside a 170? There is barely room for me and the dog.
Perhaps I could remove the drivers seat... or the rear sofa...
2015 Roadtrek 170
2011 LTV Libero
2004 GWV Classic Supreme
09-21-2015, 01:29 PM
#143
I think the only place you probably have is in the footwell of the passenger seat. That is, if you get the small chest. Doubt it would fit under the sofa.
Oh well, when you choose a small van, you make compromises. Can't have everything, even in a big van.
09-21-2015, 01:48 PM
#144
Originally Posted by mumkin
The Roadtrek models on the website show either 1 or 2 rear passenger seats right behind the front seats. Suggestion is to remove one of those to make room. Or is your layout different from current models?
BobB
'99 VW EVC
09-21-2015, 03:18 PM
#145
Some one asked for the lengthof the Zion SRT, it is 19' 9". There is a scan of the brochure from Hershey posted over in the files section of the Roadtreking Facebook group if you want to see it.
09-21-2015, 03:40 PM
#146
there are tradeoffs no matter what b floorplan you choose. on my zion the wife uses the fixed bed side and leaves it made up.
i use the couch that goes out to 42 inches wide and use a twin rvsuperbag on it comes . puts on and comes out fast.
i also like the 59k floorplan. they all have their advantages and disadvantages
09-21-2015, 03:56 PM
#147
It lists GVWR as 9350#, so that would make it a 3500, just like the regular Zion.
BobB
'99 VW EVC
09-21-2015, 08:49 PM
#148
Per Roadtrek's Billy Cochrane:
"The base price for the ZION SRT is $83,906 ($4,000 below the Zion). The pdf file is too big to load here so:
Specifications
Exterior length 19’ 7” ( 5,969 mm)
Exterior width (without mirrors) 6’ 11” ( 2,108 mm)
Interior aisle width 29” ( 737 mm)
Exterior height (with roof AC) 9’ 5” ( 2,870 mm)
Interior standing height 6’ 2” (1,905 mm)
Wheelbase 159” ( 4,039 mm)
Gross vehicle weight rating 9,350 lbs. ( 4,332 kg)
Occupant & cargo carrying capacity* 1,250 lbs. ( 565 kg)
Gross combined weight rating* 11,500 lbs. ( 5,227 kg)
Fuel type Gas 24 U.S. gal.
Fresh water capacity 140 L/37 U.S. gal.
Black holding tank capacity 36.3 L/9.6 U.S. gal.
Gray holding tank capacity 86 L/22.8 U.S. gal.
Storage capacity 1,189 L/42 cu. ft.
Rear queen sleeping maximum 74” x 62” ( 1,880mm x ,575mm)
(width x length)
(I think they have these backwards, the pic shows the bed sideways)
Front single bed (width x length) 33” x 70” ( 838 mm x ,778mm)
Coach Features Standard Optional
Air conditioner – 110 V, 11,000 BTU roof mount X
Awning – 12’ (4,000 mm) power awning X
Bathroom – permanently enclosed with sink & shower X
Battery – 400 AMP AGM X
Detectors – smoke, propane & CO X
EcoTrek 200 or 400 lithium power module X
External power connection - 110V X
Furnace – propane automatic, 16,000 BTU X
Generator – underhood 280 AMP, 12V X
Generator - Onan MicroLite gasoline (110V, 2.8Kw) X
GoSun solar oven X
Instant hot water 36,000 BTU with bypass X
Mattress – single folding X
Microwave oven – 110 V, 20 L/0.7 cu. ft., 700 W X
Monitor panel – water, propane & battery charge levels, X
battery disconnect & generator hour meter
Outdoor shower X
Portable solar cell 200 W X
Power inverter/converter/transfer switch – 12/110 V, 2,000 W X
Propane tank – 25 L/7 U.S. gal., 30 lbs. X
Rear power sofa – forward facing with fabric upholstery X
Rear power sofa – forward facing with “Halo” leather upholstery X
Refrigerator – 12 V, 5.0 cu. ft. X
Screen package – passenger side door, rear cargo door & X
side windows
Sewage disposal system – 12 V macerator sewage pump & X
gravity dump
Solar charging system – 200, 270 or 300 W with charge controller X
Stove – propane; two burner recessed with flush cover X
TV/Blu Ray – 24” HD flat screen on rotating bracket with remote
and Blu-Ray DVD player X
VoltStart - auto start battery protection technology X
Chassis Features Standard Optional
Airbag – driver & passenger X
Alternator – 220 AMP X
Axle – rear – 3.86 ratio X
Battery – 800 AMP X
Brakes – anti-lock (ABS), four wheel disc X
Camera – rearview backup X
Climate control X
Continental spare tire carrier & spare tire X
Cruise control X
Engine – 3.6 L gas V6, 24 valve X
Power – 209 kW/280 HP X
Power mirrors X
Power front door step - Driver/Passenger X
Power side entry door step X
Radio – Uconnect 5.0 - Sirius/USB/Steering wheel controls X
Bluetooth, AM/FM/CD/BT/aux/Voice command/GPS/NAV
Receiver – Class III with wiring for trailer lights X
Stability program - including wind assist, sway assist, drift X
compensation, Trailer sway, engine drag control, rollover
mitigation, Electronic stability control, Hillstart assist.
Telescopic steering X
Tires – LT225/75R16E black wall X
Torque – 352 Nm/360 lb.-ft. X
Transmission – automatic 6-speed 6S TE X
Wheels – 16” aluminum polished X
Window operation – power; front doors only X
09-21-2015, 08:54 PM
#149
the zion srt bed requires sleeping side to side
09-21-2015, 09:12 PM
#150
Last I checked my wife and I still like each other....
09-21-2015, 09:19 PM
#151
What is the "Front single bed"?
09-21-2015, 09:37 PM
#152
lol-good luck to you. i have the regular zion with side couch. my wife keeps the permanent bed side with 6 inches of foam-she likes it that way.
i use the couch side when folded out is 40 inch bed. no foam- i like firm
09-21-2015, 09:38 PM
#153
As Gerry can attest, the capacity of the SRT AGM house battery is about 186 amp hours at the standard 20 hr rate, they keep referring to it by its name SMS AGM 400, where the 400 refers to the fact that is a 400 min reserve battery. Not consistent with the usual Roadtrek nomenclature where they would refer to it as something like a 2232 watt battery (really watt hour but they like leave out the hour part).
#154
A "mattress" laid across the driver and passenger seat...
09-21-2015, 09:40 PM
#155
The front single bed goes across the two front seats, probably not for full size adults.
09-21-2015, 09:41 PM
#156
If you look at wincrasher's Hershey Report, you'll see a picture of it about three-quarters of the way through. It looks similar to the extra bed Rodatrek sells for the Chevy models that sits across the two passenger side seats, in this case it sits across the front seats.
2003 Roadtrek 190 Popular
09-21-2015, 09:48 PM
#157
What is standard and what is optional got jumbled in the copy/paste.
09-21-2015, 10:18 PM
#158
this is the zion battery
it is thin plate pure lead technology-tppl agm- superior to standard agms but not as good as lithium.
on boats it is sized battery bank like lithium because of it's rapid charging
it is NOT lithium
400 refers to reserve capacity
http://buy.northstarbattery.com/p/sms-agm-400-battery
09-21-2015, 10:37 PM
#159
it is NOT lithium
SMS-AGM-400 BatteryÂ*| NorthStar Battery
Says it can go to 80% depth of discharge. So more "usable" AH than standard AGM?
BobB
'99 VW EVC
09-21-2015, 10:47 PM
#160
i need to be careful here. tppl is superior to standard agm-however some people on boats strat treating them like they are lithium because in many ways they act like lithium.
they charge almost as fast as lithium and discharge better than standard agm but not as good as lithium.
however like standard agm important to fully recharge as soon as possible-tppl agm sulfates just like standard agm.
if your really intererested google tppl gm and boats
