Old 09-22-2015, 11:24 PM   #181
Originally Posted by Nomad32 View Post
That's a decent sized bed.
if you don't care about side to side-yes
Old 09-22-2015, 11:29 PM   #182
BobB's Avatar
I do care about side to side and it works for me. Different strokes for different folks.
They do call it a "queen", but queen size - home mattress - is usually 60x80 (some minor variation with manufacturers). So a bit wider than queen but definitely shorter.
BobB
'99 VW EVC
Old 09-23-2015, 12:13 AM   #183
wincrasher's Avatar
You can sleep the same way in a regular Zion if you wish. The only reason to go with the SRT is if you need to do city parking al ot. If your useage takes you to urban areas mostly, then you'll appreciate the shorter length.
2019 Winnebago Travato GL
Old 09-23-2015, 12:25 AM   #184
I'm single, so I sleep full-on spread eagle.
Nomad32 is offline   Reply With Quote
Old 09-23-2015, 12:30 AM   #185
Yes and it's cheaper.
Old 09-23-2015, 12:46 AM   #186
I wonder how much cheaper when both are fully loaded?
It will be interesting to compare the two models when you can build an SRT on the RT website (still not posted as of yet though).
Old 09-23-2015, 05:09 AM   #187
I don't think I needed to know that...
Scottbaldassari is offline   Reply With Quote
Old 09-23-2015, 01:44 PM   #188
wincrasher's Avatar
Well, if there is any logic to it, the difference should only be in the base cost of the van.
The cabinetry difference is minimal, so you might save a few hundred $ on that. The extra cost paint colors should also be a little less, as there is less surface area.
I'm betting, in the end, that similarly equipped vans would only be a few thousand dollars apart. The SRT is only 15" shorter, with all the mechanicals the same, so it won't be a great deal cheaper than a regular Zion.
Old 09-23-2015, 03:08 PM   #189
As posted earlier, the list is 4k less than Zion. I suspect options will cost the same. I noticed the spec sheet for both Zion and SRT list the same vehicle wt.
islandrog is offline   Reply With Quote
Old 09-23-2015, 03:10 PM   #190
That makes sense. I just wish that RT would try another floorplan, maybe similar to the Hymercar Grand Canyon.
Old 09-23-2015, 08:28 PM   #191
With all my online research, the SRT seems the best fit for us. Looking forward to the Seattle RV show this winter.
Old 09-24-2015, 05:26 AM   #192
Bad news Islandrog. The fall show was canceled this year. The next one will be in February. A couple of years ago my wife and I had a lot of fun attending the Tacoma show, although they only had one B. Does the Seattle show usually have a few more Bs present?
SEATTLE'S FALL RV SHOW 2015
This year's Fall Seattle RV Show will not take place due to venue limitations. We appreciate your support and hope that you will plan to attend the Great Seattle RV Show on February 11-14, 2016.
B Eventually is offline   Reply With Quote
Old 09-24-2015, 03:14 PM   #193
It has been a number if years since I attended the Seattle show. Actually the Feb. show is the one I am looking forward to. We will probably make the Tacoma show next month as well.
Old 10-06-2015, 07:31 PM   #194
With the introduction of a new Roadtrek model how long does it usually take for them to update their webpage and for the units to start arriving at dealerships?
Old 10-06-2015, 08:19 PM   #195
This is Roadtrek you are talking about. For all we know the SRT could have just been a concept to generate interest. Maybe they will scrap it altogether.
Old 10-06-2015, 09:09 PM   #196
wincrasher's Avatar
When I talked with Jim, it seemed like they were committed to it. They have alot of customers who want a shorter van, and supply of the Chevy Express is limited.
Old 10-06-2015, 09:53 PM   #197
If I end up getting an RV, right now the SRT comes closest to what fits my needs..... i.e. budget, quality build and size.
Old 10-17-2015, 06:54 PM   #198
First SRT I have seen on a dealer's lot.
2016 Roadtrek ZION SRT, Bristol CT - - RVtrader.com
Old 10-17-2015, 06:59 PM   #199
and it has an ecotrek battery
it's my dealer
Old 10-17-2015, 08:21 PM   #200
wincrasher's Avatar
Ha! That's the van I reported on at Hershey. Good luck with whoever buys that one.
