Old 12-19-2011, 06:19 PM   #1
Default Xantrex 15A Inline Transfer Relay
An easy to mount 15A Inline Transfer Relay provides switching between shorepower and inverter AC source. It comes with a power plug for convenient connection to the inverter GFCI and a hardwire cord for the AC input and output interface. It is available as an accessory to the Prowatt SW product line.
http://www.xantrex.com/power-products/d ... relay.aspx
From what I've seen pricing is around $50. To be used with an Inverter.
I think I'll put one of these on the line to my RV fridge. At 15 amps AC it is more than adequate for that job.
Old 12-19-2011, 11:15 PM   #2
Mike's Avatar
Default Re: Xantrex 15A Inline Transfer Relay
I was confused until I got to the bottom. So, your fridge runs off shore (obviously) and an inverter?
So, does it shut off the inverter when it senses shore AC? You know how clueless I am about RV electrical.
Old 12-19-2011, 11:41 PM   #3
No, it wouldn't shut the inverter off. AC grid current passes through when available. If off grid then the inverter takes over (if the inverter is turned on).
I think I'll get one because I like to run the fridge on AC when I'm driving around. Then I'll plug into grid power when I get to a campground this item will automatically switch the fridge to AC power not inverter power. At 15 amps I might just add this to the circuit in my van that includes the fridge and the microwave and an outlet in the back. If I don't have hook-ups then it is easy to switch the fridge to propane and turn the inverter off if not needed.
Old 12-19-2011, 11:46 PM   #4
Mike's Avatar
10-4, I think.
