Old 10-19-2019, 03:49 AM   #1
Default Winterizing a Travato
I’m going to be parked in a cold place for about 5 days. It will get to freezing temps at night. What should I do?
La Buscadora is offline   Reply With Quote
Old 10-19-2019, 03:51 AM   #2
Empty the water tanks and just use Jerry cans inside the van instead?
Van_Dreams is offline   Reply With Quote
Old 10-19-2019, 03:58 AM   #3
Thanks! I won’t be living in it. It will be parked. Should I turn on the holding g tank heaters? This is all VERY new to me!
Old 10-19-2019, 07:15 AM   #4
If you have holding tank heaters, turn them on!
Old 10-19-2019, 02:25 PM   #5
If your hooked up to electric you should use the heaters but then the tanks must have liquid in them. This will prevent spot overheating. I would go with 5 gallons or so each as a minimum.
mikeehlert is offline   Reply With Quote
Old 10-19-2019, 08:22 PM   #6
Most decent sized RV dealerships offer free or low fee clinics on winterization
