Old 07-23-2015, 05:38 PM   #241
By the way, if you are into casinos at all, there's one just right up I35 close to the Minnesota border, you could hang out at if you wanted....
Bob & Sharon
Old 07-24-2015, 03:11 PM   #242
If you're picking up at Lichtsinn's, they have hookups there in their parking lot. There are also hookups across the street at the Winnebago Visitors Center. And lastly, there are plenty of hookups (as well as shower houses) at the Winnebago Rally Grounds less than a mile away (as long as there's nothing going on). All these are electric only, I believe, but there is water available at the rally grounds for sure - don't know about the others.
James and Stef
Follow us on our blog
https://www.thefitrv.com
thefitrv is offline   Reply With Quote
Old 07-26-2015, 06:29 AM   #243
hey Travato owners- how loud is the generator? can you run the generator and run the AC for extended periods without loosing your hearing ???
RickNV is offline   Reply With Quote
Old 07-26-2015, 10:08 AM   #244
Generators are loud. Airconditioners are loud and awesome.
Old 07-26-2015, 01:39 PM   #245
Is this a trick question. the Onan generator supplies 2800 watts of alternating current and is good to have when you need it. it also
SOUNDS LIKE A MACHINE GUN SHOOTING AT A LAWNMOWER-SORT OF LIKE USING CAPITAL LETTERS IN A POST-LOL
when the air conditioner is on you hear the air conditioner and the generator-one covers the other
it's the people around you that suffer the generator
so the answer is NO!
Old 07-26-2015, 01:46 PM   #246
wincrasher's Avatar
It's loud - 78 db as I showed here:
http://www.classbforum.com/forums/f8...00-a-2938.html
2019 Winnebago Travato GL
Old 07-26-2015, 07:45 PM   #247
We've had all 3 fuel types of Onam generator. Gas, diesel & propane. Loudest to quietest in order are:
1-diesel
2-gas
3-propane
The propane is noticeably quieter than the other 2. You can buy an Onan supplied resonator and install it on all 3 and it quiets all of then down, with the propane probably the most. About $50.00 for the part. It's an Onan part so it won't hurt the warranty.
The AC is another thing all together. Every class B and class C I've ever been in, it is noisy. Some don't mind it, (us), some can't handle it.
We don't have any problem getting and staying asleep with both running, (gen & air)
Bob & Sharon
Old 07-26-2015, 10:37 PM   #248
Do you happen to have the part number for that resonator that you could share? A friend just had his 2014 into an Onan regional center for a carburetor repair and when he asked if there was anything that could be done for noise reduction he was told "no".
2016 Travato 59G
replaced 2015 Travato (1st gen)
K1200LTE
O'Fallon, MO
RTVATO is offline   Reply With Quote
Old 07-26-2015, 11:22 PM   #249
wincrasher's Avatar
As I showed in my posting, the resonator does not reduce the noise level. It simply changes the tone to be a bit less annoying. It's still hella loud.
If you decide to install the resonator, you'll need to cut your generator tailpipe, weld the resonator in and probably re-jigger the supporting hanger.
Part of the discussion in that earlier thread was that some noticed the generator was quieter over grass than it was over asphalt. Some also carried a square of carpet to lay on the ground under the exhaust pipe and that helped some in reducing the tone of the sound.
Old 07-26-2015, 11:51 PM   #250
amazon
http://www.amazon.com/Cummins-Power-...onan+resonator
Old 07-27-2015, 12:48 AM   #251
mass59k's Avatar
Send a message via Yahoo to mass59k
I would get the leveling blocks in the bag..forgot their name. Bag chairs are good too. Kindle hose for water great..much easier to use than regular type.
Wayne from Mass
2016 WGO Travato 59k
mass59k is offline   Reply With Quote
Old 07-27-2015, 04:23 AM   #252
great info - thanks everyone
Old 07-27-2015, 01:33 PM   #253
BobB's Avatar
What's a "Kindle hose"? Googled it but no hits.
Old 07-27-2015, 06:00 PM   #254
Mass59K-I be interested in your feedback on another topic where someone questioned my belief that a View/Navion could go almost anywhere a Travato could go with few exceptions. Also the View because of higher ground clearance could go where other class Bs couldn't.
Since you traded a View for a Travato 59K, I'd be interested in your real life experience feedback.
tbirdman is offline   Reply With Quote
Old 07-28-2015, 09:32 PM   #255
mass59k's Avatar
Sorry..krinkle hose..
Wayne from Mass
Old 07-28-2015, 09:35 PM   #256
mass59k's Avatar
The View can go almost anywhere. .restrictions to me would be height and wind. .when someone usesays the 59k layout and puts it on the Mercedes chassis I will trade in an instant
Wayne from Mass
Old 07-28-2015, 09:46 PM   #257
I got to see both the Travato 59G and the Agile SS...I am not almost certainly leaning towards the Roadtrek! One it being Canadian and two just seems to have things together and looks like it would work great off grid.
spike is offline   Reply With Quote
Old 07-28-2015, 10:10 PM   #258
It already exists. It is called the Coach House Arriva.
Luxury Motorhomes - Fuel Efficient Downsized Class C (Class B-Plus) RVs - Arriva
Old 07-28-2015, 10:26 PM   #259
BobB's Avatar
Lynx-levelers are the ones I got. Compact in bag
Old 07-28-2015, 10:31 PM   #260
Are you referring to the twin beds as the 24V View has the twin beds.
