Old 02-02-2020, 07:05 PM   #1
Default Windshield Privacy Curtain Track?
2004 RT 200P, one of the rivets that holds the windshield privacy curtain track has come loose from the head liner, is there a fix to secure the track?
Thanks
Johnnie
k1hog is offline   Reply With Quote
Old 02-03-2020, 03:37 AM   #2
Pop rivet?
-RV's, Firearms, and Bourbon
-Weekend warrior
BigFatGuy is offline   Reply With Quote
Old 02-03-2020, 07:20 AM   #3
Pop rivet or flat head sheet metal screw. ACE hardware has them. Sheet metal screw doesn’t require a rivet gun but they don’t cost much.
Old 02-12-2020, 12:54 AM   #4
I have tried pop rivits with limited success. I have had success using toggle bolts with spirng out wings. I used #6 screws about 3 inches long. You my have to manuever the bolt in order to make the wings spring out but when they do you get a secure fixment when you tighten the screw.
Old 02-12-2020, 01:06 AM   #5
You can actually find pop rivets with "wings"as well... They work quite well, but they extend a bit deeper than simpler rivets.
-Weekend warrior
Old 02-12-2020, 12:42 PM   #6
Thanks all for the replies, the wing rivet's look they should work, I ordered some.
Johnnie
Old 02-25-2020, 02:52 PM   #7
Default After Action Report
After Action Report
As BigFatGuy reported, i got on the interweb and found:
Small Head 3/16 Exploding Rivets Mill Finish 50 Count WMS Racing Products.
The rivets were a little larger then the original rivets so I use a small rat tail file and made the whole a little bigger.
They worked great. I have included a picture of the rivets.
