Old 05-15-2017, 07:38 PM   #1
JRB
Default Window repacement
I have a 1990 Dodge Xplorer and need to replace the small bathroom window. This type window cracks out. I don't need the complete window frame just the window itself. Does anyone know where to find these windows?
JRB is offline   Reply With Quote
Old 05-15-2017, 09:05 PM   #2
If you get stuck, look at a piece of acylic/lexan/ploycarbonate cut to size/shape.
Most cities will have a supplier.
or if handy home depot and cut to size with a jigsaw or dremel/rotozip
flat panels are easy compared to something with a curve
mike
Old 05-15-2017, 10:33 PM   #3
gklugie's Avatar
A window glass company should be able to make you a replacement. They will use tempered glass, possibly tinted to match.
gklugie is offline   Reply With Quote
Old 05-15-2017, 11:38 PM   #4
Bruceper's Avatar
Tempered glass would need to be ordered, delivery time is typically a few weeks. So while you're waiting you could throw some plexi in there for a temporary window.
You could use plate glass, but it's quite dangerous if it breaks. If you're going to use plate glass then I suggest tinting it first, so if it breaks the tint will hold it together.
Old 05-16-2017, 09:42 PM   #5
JRB
Here is a better picture. I am looking for the inner window. It slide into the window frame.
Old 03-29-2018, 09:45 PM   #6
Mat Mobile's Avatar
Have you considered asking a "glaziery"? You never know... (New word I learned today. )
