Old 01-18-2021, 09:53 PM   #1
Default Window Latch
This probably only relevant to older rvs but I have this type of window latch on my side door windows (one on each door) that pulls up and then pushes out to get air into the van. I have a single rear door with a large window (1997 PW) and it has 2 of these latches. There is also a sticker saying that you shouldn't open this window while running the engine. I've never been able to get the rear window open and when investigating found that the 2 latches appear to have a rivet in them (see pic) that appears to go through the stem of the latch and prevents it from being pulled up. Any one seen this before or know that if I drill it out the latch will work? Thanks. Glenn
Old 01-18-2021, 10:14 PM   #2
Yep. Drill it out and it will work.
It was put there on Roadtreks to keep the window closed on those units with a generator.
Pleasure way must have used it to enforce the engine exhaust gas warning.
Old 01-18-2021, 10:42 PM   #3
Jon in AZ's Avatar
Could that be true on my 2014 Roadtrek, too? I thought something was stuck, but it never occurred to me it might be intentional. Side door glass works fine but neither rear door window will open.
Learn something every day!
Old 01-19-2021, 04:08 AM   #4
jmai's Avatar
I have the same 2 latches on my 2001 Roadtrek 190 back window and I have a generator. Mine are functional and open the window. Not sure if it was modified in the past.
Joe
jmai is offline   Reply With Quote
Old 01-19-2021, 10:51 PM   #5
Thanks, hb. I'll give it a try. Any suggestions on where to get a window screen for the rear window?
Glenn
Old 01-19-2021, 10:59 PM   #6
Yep. They are called Skeeter Beeters. Magnetic net fits over the open windows. Not perfect but they work. Remove when moving.
Roadtrek just used a small screw to lock them, not a rivet.
Old 01-25-2021, 11:36 PM   #7
Attachment 11068
Those latches can get really difficult to open if they haven't been used for a while. I have a 1999 RT and had one of the back window latches replaced because I had to use both hands to pull it up. My side door window is like that too but not quite as bad. I have a generator too, but I'm not the first owner so maybe a previous owner changed the latches to open.
Pam
