Old 07-17-2023, 03:55 PM   #1
Default WiFi, Blue tooth, technology challenged
Purchased a Atoto A6PF for my 2002 Roadtrek and muddling my way through instructions. One harness has 4 wires, a large yellow one for rear camera, I got that one. Then there are 3 wires with clear plastic caps on the end. WiFi, Bluetooth and Parking.
Are the clear plastic caps the antenna or do I have to purchase antennas?
[IMG][/IMG]
Old 07-17-2023, 04:24 PM   #2
DaveBad's Avatar
Those wires with the plastic caps are the antennas. Nothing needs to be purchased.
DaveBad is offline   Reply With Quote
Old 07-17-2023, 04:58 PM   #3
Thanks for the response, This is a 2001 Chevy express, the area around the radio is a metal cage, antenna's do not do well in metal cages, will this new tech work ok??
Old 07-17-2023, 05:56 PM   #4
DaveBad's Avatar
My B is built on a 2007 Ford chassis. I installed a Boss BE62CP-C head unit. For what it’s worth, The Bluetooth antenna works fine for me.
Old 07-17-2023, 08:09 PM   #5
Thanks, appreciated
Old 07-18-2023, 07:44 AM   #6
You should be able to extend the antennas past the cage Better if you can separate them from each other
