Old 05-23-2016, 01:30 AM   #1
JimDavisHouston's Avatar
Default Why Does My Water Stink?
Hi Guys.
Got a 2015 Travato. I don't drink the water at all. When I fill my fresh water tank, I add about an ounce of Clorox, and the water has a slight chlorine scent to it. However, when I run my Hot water, it reeks of a strong Sulfur smell.
I seldom use the Hot Water tank since it only runs on 110v, but I run the water from time to time to keep it circulated. The smell is always there. Strong at first, then eases a bit, but always there.
Anyone else have this?
JimDavisHouston is offline   Reply With Quote
Old 05-23-2016, 01:46 AM   #2
eric1514's Avatar
Hydrogen Sulfide and bacteria. Don't leave water in it unless you are going to use it. I'm talking about the water heater.
Just rinse it several times with fresh water by draining it and refilling. It will clear up. When you are done, drain it again and leave it empty.
Eric
"Il Travato Rosso"
2015 Travato 59g
Old 05-23-2016, 01:56 AM   #3
If you have a magnesium anode rod, you may want to replace it with an aluminum one. The magnesium are very prone to the rotten egg smell of the hydrogen sulphide. IIRC, the chlorine just makes the smell worse.
Old 05-23-2016, 01:57 AM   #4
briancummings's Avatar
Does your tank have an Anode in it? If so I'm guessing it is shot and needs to be replaced. Just had that same problem myself and that was the cause.
briancummings is offline   Reply With Quote
Old 05-23-2016, 02:13 AM   #5
eric1514's Avatar
No anode in that particular heater.
"Il Travato Rosso"
2015 Travato 59g
Old 05-23-2016, 02:20 AM   #6
Thanks guys.
When I get home from this trip, I'll flush it real good, and check it out.
Old 05-23-2016, 02:24 AM   #7
eric1514's Avatar
Since you don't like using it, you could always turn the bypass valve to "bypass" and never fill it. That way you'd never have to drain it. Just be careful and never turn on the heating element.
Eric
"Il Travato Rosso"
2015 Travato 59g
Old 05-23-2016, 05:05 PM   #8
Good Idea Eric.
The holding water is usually warm enough for me in the shower. Easier to fill the sink, and nuke a cup of water to dump in for shaving.
I'll use the tank once or twice a year when my wife comes along.
