Old 06-06-2023, 04:51 AM   #1
Jay
Default White Roadtrek 1998 Dodge 3500 touchup
Hi All,
Does anyone have a recommendation for finding the right white touchup paint for the late 90's models of white Roadtrek? Also, the green trim would be another great thing to be able to touch up, if I only knew what to get!
Thanks,
Jay
Jay is offline   Reply With Quote
Old 06-06-2023, 01:25 PM   #2
The paint codes inside the driver's side door of my 1999 Roadtrek 170 are PW6 for the white and B8343 for the blue. I came across the following website that seems to offer touch-up paint in these colors (though the white is W6/GW6 not PW6 so perhaps that is a different shade?) but I have not tried them. If you do give them a try, let us know if they match!
https://www.paintscratch.com/touch_u...te-W6-GW6.html
https://www.paintscratch.com/touch_u...oat-B8343.html
Old 06-12-2023, 12:14 AM   #3
DUPLICOLOR BCC0362 should be what you need for the white PW6. Here is one place to get it: https://www.summitracing.com/parts/s...BoCcRAQAvD_BwE
SQUASHMIRE is offline   Reply With Quote
Old 06-12-2023, 11:14 AM   #4
That paint is supposed to match GW6 and PW6 so I guess these are both the same white color.
Old 06-13-2023, 06:16 PM   #5
Blueboy1's Avatar
I have tried them all for my 1996 Dodge, PW. without success. You will not be able to match a paint that has 20 years of exposure to the sun. These paint codes are OK, but you would need some serious buffing to blend it to the surrounding area. If you reduce your expectations for the final result, then you could reach an acceptable finish.
For the green part, I bought a small section of a cover at my local autoparts and they scanned the color and made me a match that was close to perfection, but it came out as a Toyota paint code !!
Have a nice day
Blueboy1 is offline   Reply With Quote
