Old 07-29-2015, 02:15 AM   #1
Default Where Can I get a New one of these
It's the stove top cover made by Perfect Chef apparently. Mine is quite rusty and nasty. I might try to sand blast it. Any other ideas are welcomed. Thanks for the help in advance!
Maui is offline   Reply With Quote
Old 07-29-2015, 04:51 AM   #2
Sand blast and powder coat.
sebtown is offline   Reply With Quote
Old 07-29-2015, 06:17 AM   #3
Thanks for the reply Sebtown
Old 07-29-2015, 07:53 AM   #4
New stove might be cheaper. Just to get by you could buy the really heavy kind of aluminum foil and cover it in that. Cut the holes to fit. Easy cleanup. Just throw away and redo when necessary.
Old 07-29-2015, 08:20 AM   #5
The powder coat place I took it to in Oregon sand blasted my parts before powder coating them. problem is you have rust pits, you will have rust pits afterwards.
tbirdman is offline   Reply With Quote
Old 07-29-2015, 04:05 PM   #6
BobB's Avatar
https://www.pplmotorhomes.com/parts/...pair-parts.htm
I did a quick search and found a Perfect Chef 2 burner cover, but no picture or $, so maybe they no longer have it, but you might give them a call anyway.
Old 07-30-2015, 06:00 AM   #7
hey thanks Bob!
Old 07-30-2015, 01:49 PM   #8
BobB's Avatar
Looking at the "nasty and rusty" photo, stanw909 might be on the right track. If the top is like this, what's the rest of the stove like? Burners, controls, propane connections?
Not sure if new would be cheaper, but definitely cleaner and probably safer.
BobB
'99 VW EVC
Old 07-30-2015, 06:56 PM   #9
Thanks guys-no longer available so i'll go powder coating.
