Old 11-13-2011, 07:47 PM   #1
Default Wheel Spacers Size
Hello, I have to get wheel spacers for the rear tires on my PW Excel, but I don't know what size to get, also, does anyone knows where I can get a good price on them? Everywhere I've seen them, they are expensive. Can I use spacers for an f 150 - 250? Thanks. Louie.
Itaricans is offline   Reply With Quote
Old 11-14-2011, 03:01 AM   #2
Default Re: Wheel Spacers Size
I can't say to a best source, but I will comment as to application. Wheel spacers are VERY specific to the vehicle and the application. Misapplied, they can be very hard on the equipment and dangerous. To use a 1/2 ton spacer on a 1 ton van is a very bad idea. Put the liability on the folks that make the spacers, and buy what is specifically designed for the unit you have. It isn't worth a major failure to try to save a couple of bucks.
Old 11-16-2011, 09:06 PM   #3
Photog's Avatar
Your rear axle is smaller width than your front axle. Do you know what the difference is?
Example: If it is 3" narrower, you will need 1.5" wheel spacers (2 x 1.5" = 3"). Due to the weight of our Class B rigs, these spacers should be made from steel. Steel spacers are expensive; but not as expensive as wheels, and it allows you to use the same wheels on all four corners (and spare).
Or you could use rear wheels that have a -38mm offset difference than your front wheels. But, you would then have different wheels front & rear.
The steel spacers are the least expensive, and most convenient option. Look at it this way, the spacers will probably cost less than the fuel for your next trip.
Brian
2004 Toyota 4Runner
2014 Honda CR-V
1965 Dodge Coronet 440
