Old 08-01-2012, 03:23 PM   #1
Default whats the best low amp refrigerator ??
whats the best low amp drawing 12 volt refrigerator for a van ??
i found this website and it shows one that draws 2.5 amps .is this low and is this a good brand ??? it's espensive but sounds like a good one . does anyone know of any others simular???? I also have a two part question if i place this in an enclosed regular van , should i have a air tube (i was thinking pvc pipe with a cover on top leading down to the back of this to let cooler air to it since it will be in an enclosed van so that their won't be so much hot air going into the cooling fan ??
These units feature super-low power consumption, and are designed to maintain a steady interior temperature regardless of outside temperature fluctuations. They run on 12-volt and 110-volt power and are 100% CFC/HCFC free.
lightspeed is offline   Reply With Quote
Old 08-01-2012, 10:59 PM   #2
Default Re: whats the best low amp refrigerator ??
i also ran across this on e bay :
Norcold rv refrigerator model 323T 3 WAY 120 / LP / 12 Volt
http://www.ebay.com/itm/Norcold-rv-refr ... _881wt_775
its says :
Power Source Amps 12V/AC Amps 12V/DC LP Gas
Model 323T 1.4 11.7 Yes
does this mean it draws only a.4 amps regular use ? and if so is that an hour or what? it also says 11.7 under 12 volt and ac .
i don't understand that part .
if this only uses 1.4 amps 12 volt this would use less then the 2.5 amps from the first one i showed , if i am understanding it right , hopefully someone can tell me for sure .
Old 08-01-2012, 11:30 PM   #3
11.7 amps DC
1.4 amps AC
The eBay listing has an error.
Have you seen this one: http://www.compactappliance.com/FP43...ances-Freezers
and also this post: http://www.classbforum.com/phpBB2/vi...hp?f=12&t=1696
Old 08-02-2012, 03:56 AM   #4
LightSpeed; If you haven't done so already, you might check Boosters thread on his Compressor Fridge: viewtopic.php?f=12&t=2192
It is what we would convert to - When & If...
Also check out ARB & Engle fridge websites. Just FYI.
AZ ADVenturist is offline   Reply With Quote
