02-15-2019, 12:12 AM
#121
Originally Posted by ClassB4Me
I think it's time to be brutally honest. LTV should be crafting it's marketing toward the present and future and not the past.
The Wendlands are part of a declining demographic and they remind me of Pleasantville (the movie) and not in a good way. LTV better get their AX!@$ in gear and get with the program or they will wind up like Cadillac.
The Wendlands' shtick feels terribly dated and as others have said better than I, PC Mike is no tech guy in 2019 (maybe 1980).
While LTV appears to have demand, their formula has not changed much for over a decade. No 4-season capability, No Alde heat/water, No multi-pane windows, multiplex wiring?, no advanced battery technology
Almost everything described above is no longer 'out there RV high tech design' but current design.
LTV should have been courting the Russos and not the Wendlands as Ambassadors to advise them on what is next for those who want a modern Class B / B+. Their next generation Class B+ on the new Sprinter platforms needs to change the formula and adapt to current industry best standards and not just soft close cabinet doors and trick seating arrangements
LTV is being short-sighted.
If you look at the 50 year history of the company they have adapted to deal with lots of changes including a fire that destroyed the manufacturing plant and economic downturns. I think they will continue to adapt to produce a quality product that is in demand.
02-15-2019, 12:20 AM
#122
Unfortunately this young couple have now sold their Class A and have settled into an apartment in Texas as they are expecting a baby. They plan to resume RVing after the birth.
CruiseFx
2004 Roadtrek C190 Versatile
02-15-2019, 12:36 AM
#123
Would take a lot of $250 rebates to make a dent in the price of a Pleasure Way!!
Looking for < 20 foot Class B
02-15-2019, 12:37 AM
#124
The best thing to happen to the RV industry is the ability for a much younger demographic to work remotely. We did not have to wait till retirement to buy our first RV.
Our employers simply don't care where we work as long as we account for our time and deliver on our work assignments. This change introduces customers to the RV market with much different needs / expectations from prior generations.
I hope the Russos and Padgetts speak their voices to what we need in a modern RV for working RV owners and not primarily the semi/fully retired.
To attempt to replicate ones home in an RV IMO is a wasted opportunity to do more with much less.
02-15-2019, 12:39 AM
#125
I guess Wendlend was promoting EcoTrek but now saying it is not ready yet, funny how that happens....
02-15-2019, 01:26 AM
#126
You are always going to have problem with vehicle manufacturers not being able to keep up with the new technology that is on a fast development cycle versus the slower development cycles for vehicles. There needs to be a clear separation between the new technology and the vehicle critical electronics/software in order to insure safe and reliable operation of the vehicle. This was clear before the advent of the newer software platforms like Apple Car Play which are specifically designed to be used on vehicles. The most obvious case nowdays are the OEM entertainment/navigation systems which quickly become outdated when tied to a specific closed system from one of the car audio companies. Hard to keep them current with the latest stuff coming along from the tech companies.
02-15-2019, 02:58 AM
#127
Originally Posted by Bud
"So... my opinion rather agrees with the Wendland's. I still don't think these systems are ready for prime time."
Mumkin, you do mean roadtrek, right? You're not including Pure 3 with ARV and the lastest Winnebago Pure 3's, and Zantrex whatever it is called.
Advanced RV not only has the Pure 3 Volta 48 (58.2) volt system using Lithium Nickel Manganese Cobalt Oxide (NMC) batteries but also the Lithiumwerks Valence lithium manganese Phosphate (LiFeMgPo4) batteries and the Elite Power Solutions Calb lithium phosphate batteries (LiFePo4).
I had their first build of the 800ah LiFePo4 batteries in 2014 and they are still going strong. I never had a battery problem but early on their insulated box, supposedly waterproof, was sucking in moisture in a pressure differential and shorting out my batteries when it rained. It was temporary as it usually dried out fairly quickly but it was a pain and scary at first. They solved that problem with a nickel sized plug of Gortex.
They were the first Class B with the Volta system in a higher kWh configuration than Winnebago and along with their more efficient Houghton air conditioner they could overnight with air conditioning without needing their Autogen (a much more sophisticated Voltstart). ARV Autogen has been bullet proof for me though I tend to never need it.
The Valence batteries are their newest and they are putting them inside the van. The first installation was in a 144 WB van and Sue Valentine's 144 van has it. Valence batteries are almost like drop in batteries but when Advanced RV gets done with the configuration it is more complex than just dropping in. I'm contemplating 6 of these in a group 31 configuration of 138ah each for a total of 828ah. The advantage of the Valence batteries is they can withstand cold down to -40 F. whereas the other two systems have a -4 F. limit. It might not make much difference since they've solved the battery heat issue. All three battery systems have a limit of 32 F. for charging batteries, but that is not a problem with battery heaters.
The Elite Power Solutions and the Valence batteries are couple with a Delco alternator. They no longer use Nations. They both use the Xantrex 3012 Freedom 3000w pure sine wave inverter. Volta is a all in one system of power, inverter and alternator. There is no AGM battery to "goose" these systems as eluded to with Etreks. I don't think there is any proprietary technology. There is the Silverleaf controller that ties everything together. That is a big rig Class A system that is proven.
Yes, costly, but whether you plug in to shore power or not, the electrical systems behave identically and transparently and practically don't have to think about it nor where you want to stay even in -9 deg. F. conditions boondocking as we recently encountered. But more importantly it is proven right now despite what the Wendlands and LTV are now handing you. I could never go back to AGMs nor less than the 800ah system.
02-15-2019, 04:04 AM
#128
This thread is getting a little off track...
I will say that there are also lithium battery systems from the marine market that are being used for RV applications and these systems are pretty rugged and reliable and relatively easy to use but maybe only for someone who has some knowledge of how the system operates. Mastervolt supplies the system used in our RV but Victron is used more widely in RV applications.
The main issues I see for any lithium battery system in an LTV (or any other RVs marketed to the average RV owner) is clear value for the added cost, high reliability, and absolute ease of use by an owner has no interest in understanding anything more than what was needed to use the current electrical system in today’s RVs. All the details about temperature constraints, charging operation, battery cell monitoring, etc, etc, have to be completely handled without any involvement by the owner.
I don’t think we are there yet but we may be close except for the value for the cost at today’s prices...
02-15-2019, 04:43 AM
#129
I wonder if those small Class Cs like LTV can’t handle anymore weight than a couple AGMs. I haven’t looked into it as I will never be in that market. The action of high amp hour battery systems is mostly Class B vans and Class A from what I read.
02-15-2019, 04:49 AM
#130
Well, battery weight will go down with lithiums but there will be added weight from the rest of the new system components. I have seen mention of owners doing a lithium battery switch in their LTV’s over on the Sprinter forum but I forget the details.
02-15-2019, 04:54 AM
#131
How anyone really takes them seriously is beyond me. They come off as bad flea market salesman. If not RVs, theyd be selling candles or some new cleaning sponges. Dean must not want to keep going to shows and stuff anymore. Shame, hes perfect as the face of LTV.
LTV makes some of the best C's out there. But they are very quickly becoming dated. Still using 3 way fridges. People that say lithiums arent yet ready is just wrong. If you prefer AGMs for some money savings, fine, but dont sound dumb in the process. Is LTV even using AGMs or are they still having people check water levels? Even if so, I saw they were still using 12v batteries instead of dual 6v. Which anyone who spent any time looking into battery options knows is a bad idea, unless they are lithium.
Anyone with opinions that change with the wind or with whoever is paying them isnt worth listening to. Thats just used car salesmen nonsense.
02-15-2019, 05:06 AM
#132
Yes, I was referring to the same system that Wendland was referring to...
I don't see why his job will change. He is in the sales department and I suspect that he will keep doing their videos and going to the shows. Unless, of course, he is looking to retire, but he's too young for that as yet... I'd say.
2015 Roadtrek 170
2011 LTV Libero
2004 GWV Classic Supreme
02-15-2019, 12:31 PM
#133
Post on Mike’s Group...
We are Unity owners with rear twin bed unit for 3 years. Met you both in Phoenix about a year ago and bragged about all the room we had for our two big dogs. So glad you are promoting leisure travel. They are lucky to get you on board. Figure our used unity just went up in value about 10k.
02-15-2019, 03:59 PM
#134
2015 Roadtrek 170
2011 LTV Libero
02-15-2019, 04:02 PM
#135
It's pretty funny reading some of the stuff over there......reminds me of the fable "The Emporer's New Clothes"
Regards,
Bob
2017 RT Agile SS
02-15-2019, 05:13 PM
#136
Good lord, how naive can you be???
Bob & Sharon
02-15-2019, 05:34 PM
#137
Probably shouldn't be surprised, I guess. We have all seen the extreme loyalty/support of the "fan people" on the Roadtrek sites also, and that doesn't make a lot of sense to many of us either.
02-15-2019, 06:27 PM
#138
I think the people who have not been on Mikes group don’t understand the fact that there is a large group of people who adore Mike, Jennifer, and Jim. As I have said before, the lovers are much more common than the people who don’t like them. If they are not to your liking it may hard to fathom it.
02-15-2019, 06:59 PM
#139
I think it comes down to different strokes for different folks
If there was a Have Lunch With....
A) Jim Hammill
B) Dean Corrigal (LTV)
C) Mike and Jen
D) James and Stefany (Fit RV)
I would look forward to having lunch with (B) Dean and (D) James/Stephany.
Interesting to see all the RV 'personalities' and how they get along/ not get along with one another (behind the scenes) when they are in the same space
02-15-2019, 07:32 PM
#140
A) Jim Hammill
C) Mike and Jen
We've actually had lunch with James and Stefany, twice. She is a treat. Really nice and cordial, interested in your happenings and of course class B's. He is reserved and quiet, always has those wheels turning in his head thinking about his next van mod, or house mod.
All in all a very enjoyable couple obviously very much into each other. One of those couples made for each other
