Old 11-28-2015, 05:20 AM   #1
Default What goes between the gate valve and the termination cap?
I'm replacing a bunch of rusted-out or melted bits on my black/grey water drainage system, and I can't figure out what I need at the sewer terminal. Right now there's a 3" gate valve and a termination cap, but it doesn't look like those two parts fit right together without anything in between---and it doesn't look like I'll be able to hook a sewer hose directly to the gate valve when the cap is off. Unfortunately, the old sewer terminal is borked beyond repair, so I can't disassemble it and figure out what's going on; I need to rebuild from scratch.
What am I missing here? Is this just a part that people don't need very often (and is thus hard to find), or am I an idiot? Happy to admit to the second possibility at this point
Straylight is offline   Reply With Quote
Old 11-28-2015, 12:54 PM   #2
eric1514's Avatar
What you linked is a 1.5" gate valve. Make sure you order what you really want.
Then you'll need to glue on a termination adaptor to the valve or to the end of the plumbing you construct that exits at the curb. That termination cap will then twist on.
Eric
"Il Travato Rosso"
2015 Travato 59g
