Old 05-25-2017, 06:15 AM   #1
Default What do you (can you) pull with your Class B?
Can you pull a trailer behind these Class Bs? Small car on a dolly? Just wondering if you guys pull anything. I have been thinking of buying a small enclosed trailer for Bikes and gear and what not.
Thoughts?
saenzm is offline   Reply With Quote
Old 05-25-2017, 12:31 PM   #2
Thoughts?
The short answer is -- It depends...
Which ClassB do you have?
Which engine/transmission?
What is your gross weight?
What is the permitted Combined gross weight?
Old 05-25-2017, 12:36 PM   #3
1997 Dodge 3500 PW
Old 05-25-2017, 01:10 PM   #4
hepcat's Avatar
To expand on BBQ's post...
Engine/trans combo?
Factory tow package? Tow package capacity?
GVWR of the van? Actual curb weight of the van?
GCVWR of the van?
If you answer those questions, you'll know what you'll be able to tow.
hepcat is offline   Reply With Quote
Old 05-25-2017, 01:21 PM   #5
Most of the various class b's are able to handle a small trailer for bikes and stuff. They are usually in the under 2500# range for the nice and light ones.
As the others have said, checking everything against the ratings is necessary, and it is always a good idea to have trailer brakes, even if you are below the weight the charts say you will need them.
Old 05-25-2017, 03:52 PM   #6
I agree with all the previous posters and would add that you need to know the hitch weight rating, trailer tongue weight and trailer tongue weight rating for your van.
I tow a lightweight category travel trailer (much bigger than what you describe) and find that the van makes for a good tow vehicle. I use a weight distribution hitch and my van has added rear airbag suspension. It is all very stable while being towed.
For security, if leaving the trailer unattended at campsites, you can purchase a hitch latch lock, and/or lock that blocks access to to where the ball goes and/or a wheel locking device.
Old 05-25-2017, 06:04 PM   #7
The RV model is important --
some have extended chassis (eg. the RT 210),
which might impact on the hitch weight.
Old 05-25-2017, 10:58 PM   #8
Bruceper's Avatar
If you do not know the answers to the above questions, there are some data plates on the drivers door or door sill. Take pictures of those and post them here or type out the info if you can.
Old 05-26-2017, 03:39 AM   #9
I have a 1999 American Cruiser - a lot of weight already sitting on a 3500 Dodge RAM Maxi heavy duty van chassis. I have a 5'x8' mesh floor utility trailer and I use it to pull a golf cart and tubs-o-stuff. The Cruiser does fine with this and the most I would do beyond this is upgrade my utility trailer.
2003 Club Car GS
rjf7g is offline   Reply With Quote
