Old 07-09-2019, 10:32 PM   #1
Default Wfco 55amp power convert for shore power
Hello,
When I purchased my van, there was a 55amp wfco power converter that came with it. Can I rewire this to use as a charging device for shore power? I want to connect it to my auxiliary battery so I can charge it while I am at campground. Thanks in advance!
Max_Baron is offline   Reply With Quote
Old 07-09-2019, 11:50 PM   #2
It should already be set up as a charger.
Old 07-09-2019, 11:53 PM   #3
So I gutted the whole van and the previous owner was using it as a way to plug in his electronics to the inverter and use that. Everything in the van was hooked up through the converter. Now that I have rebuilt the van, I wanted to reuse that converter as a charger for shore power at the campgrounds. So your saying that will work if I connect it to the battery and plug it into the outlets at the site?
Old 07-10-2019, 12:01 AM   #4
If you could give the model number, hopefully, we can look it up and find out what exactly it has for capabilities.
Old 07-10-2019, 12:08 AM   #5
It’s a Wfco 55 amp WF-9855 converter. I have a 200amp 12volt renogy battery that It would be charging. Thank you!
Old 07-10-2019, 12:32 AM   #6
It is a 3 stage charger done similarly to a Progressive Dynamics. 5 hours or until 5 amps at 14.4v then 44 hours at 13.6v and then float at 13.2v. Depending on battery bank size, it could be OK or not so OK a charger, I think. No temperature compensation, which is too bad. There are worse out there for sure, and some better. A battery monitor will tell you quickly how well it is doing, and IMO every system should have a monitor on it if possible.
Manual here
https://wfcoelectronics.com/wp-conte...Manual-web.pdf
Old 07-10-2019, 10:14 PM   #7
@Michael's Avatar
It should work.
