Old 08-16-2016, 11:46 PM   #1
peppster66's Avatar
Default Weather stripping replacements
Hi, I have an older 97 Roadtrek with the 3 spaceship windows up top, the weather stripping around these windows are starting to show their age, cracking and one is really shrinking up, just wanted to ask if anyone else here has found a place to buy replacements for these weather stripping, for these windows. I have tried my local auto shops, but no luck so far, if you have any ideas, it would be great to hear, thanks,,,, take care,,,,,,,,, Josef,,,,,
peppster66 is offline   Reply With Quote
Old 08-17-2016, 05:24 AM   #2
steele rubber products makes seals for a billion new and old cars
check them out, I am sure that Roadtrek used an off the shelf seal type rather than something proprietary.
the key as you'll see from steele is the profile of the seal and the dimensions of
window seals are pretty easy using a piece of string- if unsure call a car window guy, his 12 year old will do it in 5 minutes
like anything "repaired" rather than replaced you want an old timey guy who will fix stuff- he may even have a roll of the seal you need
http://www.steelerubber.com/
make sure you check the RV section
mike
Old 08-17-2016, 06:17 PM   #3
peppster66's Avatar
Thanks, thats great,,,,,,,
Old 09-26-2016, 04:03 PM   #4
Peppster,
Any progress? Redoing those windows on my '95 Popular 210 is on my list of to-dos.
TIA,
Mac
Sent from my SM-G900V using Tapatalk
macattack_ga is offline   Reply With Quote
Old 02-19-2017, 03:25 AM   #5
Any progress? I have a 02 Popular 200 and need new gaskets for my rear tilt windows. Also need glue that actually works for gluing the metal brackets to the glass. Thanks for the help in advance
roadytreker is offline   Reply With Quote
